Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Front facing camera replacement
Hi there
I need to replace the front mic of an iphone 6s plus. I suppose that I need to replace the camera and everything at the same time. Would the camera form iPhone 6s work?
This one here: iPhone 6s Front Camera and Sensor Cable
regards
Frímann
Immagine Replace a front camera and sensor cable assembly compatible with the iPhone 6s. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00123-01.
Prodotto
$22.99
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
laukur, Directly from your link in your question. Compatibility of iPhone 6s Front Camera and Sensor Cable, Item code: IF314-015-3 for All iPhone 6s , ((Not iPhone 6, 6 Plus, or 6s Plus)).
As far as having to replace the camera because you need to replace a bad mic. which is part of the lightning assy., camera should not have to be replaced unless defective.
Lightning Connector Part Assembly includes:
Lightning connector
Dual microphones
Headphone jack
Links below are for replacement part and guide for installation of the Lightning Connector Assy..
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s Plus Lightning Connector and Headphone Jack
Connettore Lightning e jack cuffie iPhone 6s Plus
Immagine Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A.
Prodotto
$24.99
Punteggio 1
1 Commento:
TL:DR You need to use the 6s plus front replacement camera.
The normal 6S front cam will not work.
da
Hi and thanks for your reply! However I think there is some misunderstanding. It's the front mic by the earpiece and close to the front facing camera (facetime camera often called) that is broken. I believe your directions were for the mics at the bottom of the phone (by the headphone jack)
Regards
Frimann
Punteggio 0
Aggiungi la tua risposta
laukur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 157
