Salta al contenuto principale
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
How to remove a Stripped Screw from pcb.
Hi, i have 2.5'' hdd with a torx (T6) screw on the pcb that from the force it's turned into a round hole.
I have used the rubber band method but still no luck.Also i cannot use a heat gun cause the microchips may get loose.
I must try at all cost not to damage the pcb.
Here is some images.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@pydev, Nick, Hardly looks like the head of a screw any more. Does not appear enough material left to cut a slot in it so I recommend you carefully drill the head off using a wee bit bigger metal bit (larger then the threaded O.D. of screw) in a power drill, remove the board and hopefully there will be enough shaft remaining of screw to turn out with small vise grips/pliers. Guide below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Come rimuovere una vite danneggiata
Punteggio 2
4 Commenti:
but if i remove the head with a drill how im gonna take the rest out of the hole?
da
@pydev, Nick, That is where the problem could become difficult again, if all else fails, drill carefully just enough for screw head removal and hopefully there will be enough screw shaft to grab with small vise grips/pliers to turn remaining portion of screw out after board is removed. Good luck.
da
After you cut the head off and remove the board, the stub will be sticking out. Use something like this to grab it and turn it out: Screw Extracting Pliers
da
Thank you all hope it goes well
da
I have the same problem trying to get my ps3 super slim HDD out of the enclosure
I did everything but I have no. Dremmle
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 34
Tutti i Tempi: 11,902
