Salta al contenuto principale
Repair and disassembly guides for Kenmore Microwaves.
My microwave just stopped. The outlet is getting power. No light?
It is a Kenmore model 721.89941490. Above range style. I am wondering if it can be a fuse. We have had no problems until now.
Questa è una buona domanda?
Punteggio 11
9 Commenti
It has no power to the clock, or power pad.
da
I just bought my oster microwave and there is no power what so ever.
Can anyone help me solve
da
kimnrhoades, in order to help you solve the problem it would be best to give more information. Is it new? Is it second hand? Have you checked to see if there is power to the sock that you have the microwave plugged into?
da
What could be the fault if microwave keep cutting off fuse immediately it pick?
da
I have a kitchen aid under Cabinet microwave and replaced all 3 bulbs it was working before I did so but as soon as I placed the one inside and plugged it back in and as soon as I opened it there's nothing it's like a fuse blew,is that possible
da
Mostra altri 4 commenti
Aggiungi un commento
5 Risposte
Soluzione Prescelta
These things will kill you. I don't recommend trying to fix it. I wouldn't even try to fix my own. Either get a new one (they're relatively cheap now) or call a serviceman. Your fuse has probably blown out but there's a reason it did so please don't mess with it.
Punteggio 5
7 Commenti:
Absolutely agree. That stuff you don't want to mess with.
da
Thank you. I think you offered the best advice of all. I do know enough about electricity not to touch anything I don't understand. I'll simply heat foods and coffee the old fashioned way - on the stove or in the oven - until I save up for a new microwave.
da
go to back inside where the cord meets from inside to out. There inside next to relay will be a ceramic fuse. Most likely that's your culprit if it just doesn't show any power going to it
da
Likely the fuse blew. Unplugged oven, GFI socket works fine (test with fan). Let it sit, plugged it back in. Nothing. Display doesn't light, no interior lamp when door opens. No externally visible fuse.
Usually there's a reason a slow-blow fuse opens. When I don't know why a fuse blew, I suspect it did its job .
Failed oven made in 2016. Cost between $125 and 175.
Replacement cost 154 + tax.
Bummed I can't fix it, can't see buying a $$ fuse to see if it blows too. What resistance should I read on the load side of the open fuse? Dunno. I remember when TVs melted the wax from flyback transformers. A hard fail somewhere else.
I've fixed all kinds of problems, professionally. For $154 plus tax I don't have a service or repair cost, and don't have to wonder. Send 1 paper grocery bag to land fill, a week. Litter box contents. Used Kleenex(tm). Broken glass or ceramic. Paper-plastic blends. Everything else composted or recycled. Ok w/ a microwave every 8 years.
da
@billabbott
What is the make and model number of the oven?
Sometimes it is the door interlock switches that are the problem.
The contacts of the switch can weld together so that as soon as the door is closed etc the fuse blows.
This can happen for two reasons:
1. The switches are loose and are not operating /releasing when they should be.
2. Mis-operation of the oven by the user. The door interlock switches arer a safety feature designed to stop the oven from operating when the door is opened thereby preventing harmful microwave radiation from escaping the oven cavity. When the door is closed the oven cavity acts like a Faraday cage and contains the microwaves. The problem is that people just open the door to stop the oven when they think it has cooked far enough or they want to add things etc rather than using the oven controls i.e. pause button or start/stop button.
This causes an arc to occur over the the door switch contacts, which leads to contact material migration between the contacts eventually welding them together.
Maybe worth checking the door interlock switch to see if they're short circuit when they're not supposed to be.
da
Mostra altri 2 commenti
Risposta Più Utile
Although I agree with not touching anything inside the unit a fuse replacement is an easy fix. on most microwaves all you do is remove the cabinet and you should see the fuse in the open. use a fuse removal tool and replace it with the same voltage and amp fuse. DON'T TOUCH ANYTHING ELSE!!!! The capacitor inside the has enough voltage up to 300 volts to deliver a good zap. The magnatron from what I understand will kill you.
Punteggio 6
2 Commenti:
Don’t let all the sissy’s scare you, No capacitor in the world has enough volts to kill you. To start off volts do not kill you amperage does.. and if you are really dumb enough to touch wire connections than natural selection has taken its course… but test the outlet for power should have between 110-120 volts if not google how to change a outlet not hard. If you have power at the outlet it’s more than likely a fuse depending on your microwave there are Manuals witch will literally walk you through changing the fuse out normally 4-6 screws off the back to expose the fuse. Google will be your best friend.
da
@Cori Rain
The voltage stored in the HV capacitor of a microwave oven is in the range of 4KV- 6KV DC.
This amount of voltage can seriously injure you or even kill you if you have a heart condition.
The HV capacitor needs to be correctly discharged before any work is done inside the oven
Without even touching the wires, try discharging the capacitor using an inappropriate tool e.g. a small screwdriver and check what it can do to it. Be careful as the resultant flash can be blinding and the tip of the screwdriver has either melted or been welded to the capacitor.
I realize that a screwdriver is more conductive than the human body but using Ohm's law with a screwdriver having a resistance value of even 10 Ohms will give a current flow of 400A-600A if only for a second or two depending on the discharge TC (time constant) value of the capacitor (TC in seconds = C µF x R Ohms) and that is long enough
Here's a link that shows how the body can be affected by an electric current.
da
It is difficult to give an exact answer from your question since more information is needed. To narrow the fault down a technician will make a number of observations and tests. You have made a start but here are a few more:
  1. Is the display indicating anything? Since you outlet is working it is therefore a fault in the microwave.
  2. Unplug the microwave and remove the covers. There is usually no safely issues in working on an unplugged microwave except that on very rare occasions the high voltage capacitor may remain charged. Shorting it is a quick indication whether is charged and will also make it safe.
  3. Check the main fuse (usually located on a circuit board where the power cable terminates.
  4. If it is blown there would be any number of causes including a power surge, faulty door switches, etc. A technician will be able to determine the cause.
Punteggio 3
3 Commenti:
I unplugged mine let it sit 10 min plug it back in and in3 min it lit up and is fine. Kinda like when your dish or cable goes down. It need a reboot
da
Did not have sparks or any blown fuses.
da
There wouldn't be a so called spark from a blown fuse because it's a ceramic fuse which would just break.
da
I would bet the number of non-qualified people that have repaired or attempted to repair their microwave is easily in the tens if thousands. Yet I have never heard of a single death. Relax people.
Microwave working but not heating: Most likely the magnetron is bad. I wouldn't recommend replacing this part unless you actually know what a capacitor is and how to discharge one.
No power at all: Most likely the internal fuse. As previously mentioned above, follow the power cord into circuit board. Check ceramic fuse with an ohm meter if possible or just replace it. Replace it with the EXACT SAME fuse that you took out. It is possible that it took a surge and blew. It is perfectly safe to replace.
Internet search for your make and model, there are a lot of parts, schematics and diagrams available. Obviously buy from a reputable retailer.
NEVER EVER run a microwave without all the covers in place. The covers can possibly be shielded and that is what prevents actual microwaves from escaping into you, your family, friends and your pets.
So honestly, if my microwave had a blown fuse and I trashed it for a new one I would feel like I traded in my car because the battery was dead. We all need to minimize our disposable habits. Stay safe and use common sense.
Punteggio 2
1 Commento:
I will expand on that:
Microwave working but not heating: HV fuse, inverter, or magnetron.
No power at all: Almost always the mains fuse
A microwave oven can be run without the cover because the cavity itself is a Faraday cage for the microwave radiation.
da
This guy is right on the money and we all should thank him here.
So, thank you!!
Punteggio 0
Aggiungi la tua risposta
Bonnie Hammack sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 35
Ultimi 30 Giorni: 173
Tutti i Tempi: 201,099
