Odd speaker issues after front pannel change.
I have a working iphone 7 plus with a cracked screen. It landed face down on a rock. The case didn't help much.
Problem is when i move the components to the new screen the mic doesn't work. i try to hold down the home button and talk to siri and nothing. I moved the components(home button, top ribbon cable, along with a square double sided sticky tape, and two mounting clear houses) back over to the broken front panel and everything works fine.
I have done this back and forth a couple times now to make sure nothing is damaged and i can't mic and phone working when i put in the new lcd screen.
I have done a factory reset and that didn't help at all.
Any tips or information on this? Do i have have a defective lcd/digitizer?
Questa è una buona domanda?
1 Commento
Just an update. The new front camera/mic ribbon fixed the issue. I must have barley damaged the ribbon cable when moving it over. When you pull up on it to take if out it can start to separate, i'm assuming it separated more then it should have for me. maybe moving it back and forth i got a luck connection but not sure. All i know is the mic fixed it.
good luck out there and happy repairs.
da Domaa Smalls
