Salta al contenuto principale
Fourth generation Samsung Android tablets. Released in April 2014.
20 Domande Visualizza tutte
Tablet discharge within a few minutes some times.
Sometimes it takes hours to load the tablet completly and it even discharge while atached to the charging cable.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Replacing the battery should fix the discharge problem. Luckily, ifixit sells it.
Galaxy Tab 4 10.1 Battery
However, if it doesn't charge well even after the battery replacement, your charging port/cable is bad or your charger isn't powerful enough. First, get a brand new Samsung cable. Not a flimsy one you would get at a convenience store. Also, make sure your charger is at least 2.1A 5v. If neither of those fix it, you'll have to replace the charge port.
Hope this helps!
Nexus 9 AC Power Adapter and Charging Cable
Immagine Replace a 6800 mAh battery compatible with a Galaxy Tab 4 10.1 tablet.
Prodotto
$24.99
Immagine Replace the AC power wall adapter and charging cable for the Google Nexus 9.
Prodotto
$12.99
Punteggio 2
Are you using the original charger?
Punteggio 0
1 Commento:
Yes, I also tried another one and the same result.
But it doesnt happend every time.
da
Aggiungi la tua risposta
Paul Matho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 842
