Tablet discharge within a few minutes some times.
Sometimes it takes hours to load the tablet completly and it even discharge while atached to the charging cable.
Questa è una buona domanda?
Replacing the battery should fix the discharge problem. Luckily, ifixit sells it.
However, if it doesn't charge well even after the battery replacement, your charging port/cable is bad or your charger isn't powerful enough. First, get a brand new Samsung cable. Not a flimsy one you would get at a convenience store. Also, make sure your charger is at least 2.1A 5v. If neither of those fix it, you'll have to replace the charge port.
Hope this helps!
Prodotto
$24.99
Prodotto
$12.99
Are you using the original charger?
Yes, I also tried another one and the same result.
But it doesnt happend every time.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 828
