Salta al contenuto principale
Desktops developed by eMachines. eMachines has since been discontinued by the Acer Group.
58 Domande Visualizza tutte
Adding memory to may computer
Adding memory. How do I find out what memory sticks I need for an emachines ET1331G which has 4 mg of memory now. I would like to add more memory. Can anyone help me with this problem.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
http://www.crucial.com/usa/en/compatible...
Thats what you need. Just scan your system using that and see what it tells you.
Punteggio 2
1 Commento:
Thanks much and I have ordered the correct memory!
da
Risposta Più Utile
You can upgrade your eMachines ET1331G-03w Computer to up to a maximum memory capacity of 8GB Memory.
The Computer has 4 (4 banks of 1) to install memory, already with 1GB standard memory installed. For best ET1331G-03w Computer performance use the maximum amount of 8GB, fill all the slots with the max allowed memory per slot for your Computer.
- See more at: http://www.memorystock.com/memory/eMachi...
Punteggio 4
1 Commento:
Thanks much for your reply. I have ordered memory from Memorystock.
da
Hi @bluedog1us ,
As best as I can find out your eMachines desktop has a maximum capability of 8GB of memory.
According to both the Crucial memory finder and the Kingston memory finder, your desktop can use either:
1GB x PC2-6400 (DDR2 800) 1.8V 240 pin DIMM memory sticks or
2GB x PC2-6400 (DDR2 800) 1.8V 240 pin DIMM memory sticks.
Depending on the configuration you have now, i.e. is it 4 x 1GB,2 x 2GB or even 1 x 2Gb + 1 x1Gb +1 x 1GB and also what speed the current memory is i.e. is it PC2 5300 (DDR 2 667) for example, will determine what memory you purchase to upgrade it to the maximum of 8GB. If you leave the existing memory in and it is DDR2 667 and add DDR 2 800 then it will operate at the slower speed.
You may also wish to consider replacing the HDD with an SSD and then using the SSD as the OS drive and the HDD as the storage drive if you wish to gain an improvement in performance.
Punteggio 2
1 Commento:
M395T1K66AZ4-CE600 Samsung 8GB PC2-5300 DDR2-667MHz ECC Fully Buffered CL5 240-Pin DIMM Dual Rank Memory Module
da
Hey @bluedog1us , hope that you found your answer but I also like to add that if you are using eMachines Desktop PC ET1331G and having slow RAM issue, then I will suggest you to find the most compatible and fastest DDR2 RAM Memory for your system.
Here I like to mentioned one of the best memory supplier Memory4Less.com where you can find all types of computer ram from top brands like Crucial, Samsung, IBM, Kingston, Micron and more.
Please take a review at http://www.memory4less.com/crucial-memor... and find the most compatible ram for your ET1331G Desktop PC.
Punteggio 1
Aggiungi la tua risposta
Bobby Young sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,336
