Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
Camera not sharp after case replacement
I replaced the housing of my iPhone 6, now my back camera isnt focusing anymore.
So I thought I broke the camera, I replaced the camera with a new one but it is still the same issue.
The images are blurred, can anyone help me with this?
Questa è una buona domanda?
Punteggio 0
1 Commento
I will open my phone tomorrow and let you guys know, thanks!
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
I would check out the "lens" in the housing. It may be dirty or have a fingerprint on it. You will need to clean it with either a magic pen or some IPA and a clean q-tip.
Punteggio 1
2 Commenti:
It is a custom housing and I believe it doesnt have a lens in the housing.
Could that be the problem?
da
If there was no lens, then it wouldn't be blurry unless it was the camera itself that was the issue.
da
Hi,
Custom or non original housings tend to have a low quality plastic lens.
This would need removing and replaced with a glass lens.
Or there may be dirt on the lens itself.
Punteggio 1
2 Commenti:
Or a foil of protective nylon.
da
Or that also!
da
Cleaning the lens fixed the issue.
Punteggio 0
If the lens is missing it causes a blurry picture.
Punteggio 0
Aggiungi la tua risposta
Zackito sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 394
