Salta al contenuto principale
La Nikon N80 (conosciuta anche come F80) è una fotocamera SLR 35mm. È stata lanciata nel gennaio 2000 ed è identificata dal numero di modello 1776.
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
Punteggio 3
3 Commenti:
Thanks for the tip. I will certainly give it a try.
da Condividi
I had been on the guide page, but I didn't notice the repair manual tucked in there.
da Condividi
It's a present added after you asked the question
da Condividi
Aggiungi la tua risposta
Eric Zulaski sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 33
Tutti i Tempi: 620
