How do I open this!? (focal spirit pro)
Right side of my headphones stop working so im trying to open the can on to attemp a fix, resoldering another cable or something; but lord this thins are imposibbrruu to open:
is there any tool to open this up?
Questa è una buona domanda?
2 Commenti
Hi,
Have you proved that the problem is in the right headphone and not in the cable or the plug?
Try connecting an Ohmmeter (meter function found in most DMM (Digital MultiMeter - available from larger hardware stores for as little as $10) between the ring and sleeve connectors on the plug and see if you get a reading. By all accounts you shouldn't as the right side is not working.
(Place the leads across the tip and sleeve to prove that you are doing it right. You should get a reading as this is the circuit connections for the left headphone)
Then, with the Ohmmeter leads still connected across the two places on the plug (R & S on a TRS tip, ring, sleeve plug) try flexing the cable where it leaves the plug to see if a meter reading comes and goes. if it does it proves that the cable is fractured where it leaves the plug.
If still no reading then try flexing the cable at the entry to the headphones and see if you can get a reading. If you can then the cable is fractured there. if still no reading then you'll have to open it, which you will have to anyway if the cable is fractured at the headphones end.
Apologies that i can't help with that but if the problem is at the plug end that is an easier fix.
da jayeff
well i've tried different cables and it's the same result :( almost certain that it is the cable or even the female jack, wich i think i would also have problems with the right side of my headphones.
Thanks for the reply jayeff
da rg.marioevaristo
