Broken charger port on go pro 3
Can the charging port on a GoPro 3 be repaired or replaced
Questa è una buona domanda?
@rappin9 ,Rodney, The charging port on a GoPro 3 can be repaired or replaced. This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the GoPro Hero3 to check the charge port and will also post a link showing what is involved in repairing/replacing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
I got fixed by a company in Montreal, it cost me CAD$80 and they did a great job just in 24 hours working as new again.
Sebastian - which company in Montreal fixed it? i have the same problem. Merci!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,522
