Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
My touch id stopped working . How to fix ripped cable?
I have the original lcd shield and home button to iphone i had the screens switched and the repairman ripped the home buttons flex cable from the connector and button itself can i fix it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If the home button cable itself is ripped, the only way to have the Touch ID function work again is to have Apple replace it. A replacement home button will give you home button functionality but not Touch ID. If it's just the extension cable that's on the thermal plate that is damaged, that can easily be replaced and will restore home button and Touch ID functionality.
Punteggio 2
1 Commento:
Thanks. Very helpful
da
Risposta Più Utile
Hi Ty S,
Here is a guide on how to do the replacement. You may have to have the repair done by Apple in order to keep the touchID feature.
Punteggio 3
If the cable was damaged by the one who repaired the phone then have the repair done by that repair guy . Anything I break while repairing a phone I fix as it should be with all repairs . The home button can be replaced but the touch function has to be done by Apple
Punteggio 3
Aggiungi la tua risposta
Ty S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 237
