Why is my radio not turning on?
whenever i turn on the car the time will flash on then turn off and my radio wont start up
Questa è una buona domanda?
First thing to check is the fuse.
@col_panek This is more of a comment not an answer. Also, the op said the radio flashed, assuming there is power going to it
I never assume anything.
Check that fuse #28 (& possibly #39) in the passenger compartment fuse panel are OK. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the fuse panel cover to gain access to the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
Here’s an image from the owner manual to show you the fuse locations in the fuse panel.
(click on image to enlarge for better viewing)
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 62
Tutti i Tempi: 6,481
3 Commenti
Did you push the power button on the radio?
da Cameron
yes i did but still off
da Tsoxmonto Tsokos
I have a 2010 Ford Focus SE radio won't come on What's . Show ever
da jasonoverbey4
