Salta al contenuto principale
The Panasonic ARC ES-LT3N electric razor was released in April 2015. The sure-grip handle provides ergonomic comfort, and advanced 3D Multi-Flex Pivoting Head that moves up-and-down, side-to-side and back-and-forth to conform closely to facial contours for more efficient shavings.
Why does my razor keep getting hot?
Recently my razor keeps getting hot when I try to shave, what do I do?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If the outer foil is getting hot check to see if it is damaged or deformed. If so it needs to be replaced. Also, the razor may not operate if it is in an environment that is lower than 41 degrees F (5 degrees C).
Punteggio 1
Aggiungi la tua risposta
Eric Mosley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 348
