Hi,
What is the model number of your laptop?
What OS is installed on the laptop? Have you got the latest WiFi network adapter drivers appropriate to your laptop and OS installed?
Does the WiFi work OK when you are very close, (I mean very close) to the router? If so perhaps there is a loose WiFi antenna connection in the laptop
Download, install and run a WiFi scanner program on your laptop (this one is free, there are others if you prefer, just search online for WiFi scanner program). Use it to check the WiFi signal level, received by your laptop. Remember that the signal level is in -ve values, therefore the higher the number the lower the signal strength, e.g. -100dBm is weaker than -93dBm.
If you are receiving low level signals then perhaps the antenna connection to the WiFi is loose.
Also another way to improve WiFi (although perhaps not in your case as other devices are OK) is to check which 'channel' your network is using. By default most networks use Channels 1, 6 or 11. If you find that the scanner detects other networks using the same channel as yours and their signal is relatively strong in comparison to yours then change the channel in the router to a 'quieter' one (one that doesn't appear in the scanner list of channels or has minimal appearances ) to minimize any possible degradation to your network through interference.
Votato
Annulla
Punteggio
4
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti
Ok so this started a few weeks ago and for no particular reason I would lose connection and the laptop would show my network as being unidentified.
There was never a problem with any other device , phones etc.
After numerous retries it would eventually connect.
I found today that the Router, a Frontier (Greenwise) device had defaulted to WPA2 and the laptop was set to WEP as it has always been.
I set the Laptop to WPA2 and entered my password and bingo! it connected as soon as I pulled the Ethernet cord out of the Router
da Ewm002
Been running for 48 hours now. Totally solid connection
da Ewm002
I have a Toshiba Satellite S55T-B5273NR and it does the same thing. Sometimes it connects to my wifi and most of the time it doesn't. But my mobile phone and desktop have no issues. Why is that?
da Dennis Randle
Hi @Dennis Randle ,
Does it connect and stay connected OK if you use the laptop as close as possible to the WiFi router?
If so just wondering if there is an antenna problem in the laptop.
da jayeff
