Hi Kicki Squi,
Verify that you have the latest Dell Win 10 64-bit WiFi drivers installed in the laptop.
Here is a link to the support page.
Scroll down and click on the Network (9 Files) link to see the various options.
You will have to go to Device Manager in your laptop to find out exactly which make of WiFi you have installed, so that you can download the correct driver. To get to Device Manager, right click on the start button in the lower left corner on the Taskbar. An options box will appear on the left side of the screen. Click on the link to Device Manager.
When in Device Manager, scroll down and click on the + sign next to Network Adapters to expand the list and then find the make and model of the WiFi network adapter. When you have found this you can download the correct drivers from the Dell download page.
Once you have downloaded the driver, (remember where you saved the file to), go back to Device Manager and right click on the WiFi network adapter, select Update driver and when given the option to Search online or select from a disc etc, select that option and then point to the saved downloaded file location to begin the driver update.
If updating the drivers doesn't help, try downloading and installing a free WiFi scanner program to get information regarding things such as WiFi signal level and the network channel number to see if there may be either a hardware problem with the laptop or perhaps interference on the network affecting your laptop
Votato
Annulla
Punteggio
6
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
8 Commenti
Hi,
What is the model number of your laptop?
Does it stay connected if you are using it close to the router, say within 1 metre?
da jayeff
Hi Kicki Squi,
I think you may have given me a serial number not a model number. There should be a label on the back of the laptop with the information on it.
Here is an example for a Dell Inspiron 1750
da jayeff
Does it manage to connect in the first place?
da George A.
Sorry jayeff, I don't know too much about this stuff. How about Dell Inspiron 3558?
George A., yes it does.
da Kicki Squi
Try forgetting the network then re-entering the password. Sometimes the device thinks it's connected then relizes it's not. I does that because the password is wrong.
da George A.
Mostra altri 3 commenti
