Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Domande Visualizza tutte
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
Punteggio 2
4 Commenti:
I'm sorry I should of mentioned that I have a 3.0
da
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
da
On the 2.2 do u have to take the timing cover off to get to the sensor
da
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
da
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
Punteggio 0
2 Commenti:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
da
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
da
Aggiungi la tua risposta
Patrick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 77
Tutti i Tempi: 6,944
