Salta al contenuto principale
Modello A1502 con processore Intel dual core da 2,4, 2,6 o 2,8 GHz. Sul mercato dall'ottobre 2013.
552 Domande Visualizza tutte
Phillips # 000 screwdriver did not fit in replacing fan.
I bought the 64 Bit Driver Kit that you sell.
It proceeded to repair the way that you introduce.
in step#9, Phillips # 000 screwdriver did not fit in replacing fan.
I bought a 64bit driver kit, and it says that there is a Phillips # 000 screwdriver.
Any screwdriver inside it could not be repaired.
If I knew in advance that this driver set would not be repairable, I would not have bought it.
I want to hear you opinion.
thank you.
mail : changho.park79@gmail.com
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thanks for the answer.
but, If you look at step9 of the video you sent,
Red : Four 2.6 mm T5 screws
orange : One 2.4 mm Phillips #000 screw.
I can not find " 2.4 mm Phillips # 000 screw" in 64bit driver kit
Is there a 2.4 mm Phillips # 000 screw in the 64bit driver kit?
Punteggio 0
1 Commento:
Yes, there is a #000 screwdriver in that set. If you are missing it, I would recommend contacting iFixit directly here http://help.ifixit.com/category/133-cont...
da
Risposta Più Utile
The 13" Retina 2013 uses T5 screws for the fan, not Phillips #000. This should come in your toolkit.
Sostituzione ventola MacBook Pro Retina 13" fine 2013
Punteggio 2
Aggiungi la tua risposta
park changho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 223
