Salta al contenuto principale
Screen comes on and off all the time
Hi I recently bough a hp 15 p158sa touch screen one.. I though replacing the screen would solve the the problem of the screen going on and off when it like and when move the screen usually ends up with a really fuzzy screen usually green or blue. I'm currently waiting on new screen ribbon coming from a working laptop going to try that but does anyone have any ideas
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi,
Just to eliminate some other possibilities try connecting an external monitor and check that its' display remains on and clear.
da
Aggiungi un commento
1 Risposta
It does sound like your screen cable is damaged or making a bad connection. Replacing it should hopefully fix the problem. But screen going on and off and also getting fuzzy really sounds like a bad cable. So you buying the cable was best and that should fix your issue.
Punteggio 0
Aggiungi la tua risposta
hughesy_rules sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 47
