replace the swiffer vac circuit board?
can you buy or repair the swiffer vac control board?
Questa è una buona domanda?
@uncledave11 , Dave, I did not find any one selling the replacement board. If you or a friend have some knowledge of using a DVOM and some familiarity with components on a board, capacitors, resistors and diodes you can test and some times visually see defect and replace parts. Below 1st link will get you inside the vacuum to the board I believe and the other 2 links are some tutorials on how to test and visual for failed components. Good luck.
Swiffer SweeperVac Battery Replacement (PG3000)
Is silver or cardboard side placed on the battery? Step 3 - photo look like silver side on battery. Step 5 - photo, unable to tell
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 17
Tutti i Tempi: 632
