Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
will logic board from iPhone 6 work on 6s?
i have an iphone 6s that is icloud lock i was looking into replacing the logic board, i was just wondering if i could replace it with the logic board in my iphone 6
Questa è una buona domanda?
Punteggio 2
1 Commento
what if u use iphone 6plus logic board to 6s plus does dat work?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Vedi il contenuto dell'immagine:
Punteggio 3
2 Commenti:
No it will not work or would be possible.
da
If I recall correctly there are a few threads here on ifixit regarding the iPhone logic board swap.
I know that Apple has a different connector on the screens for most of the generations. So the different logic boards would need that connector as well to correspond with the appropriate display.
Also if you look at the ifixit parts pages it sometimes not that a display will only fit the specific model. That is because of the differences in the connectors and software that drives the phone and all the subsidiary components.
I would not recommend trying to swap different model logic boards. The connectors as very small and just 1 pin in a slightly different location can cause a huge headache. Best of looking for a replacement with in the same model.
Punteggio 0
1 Commento:
yeah, thats what i thought, i just wanted confirmation, i been looking into getting a new logic board but havent had any luck, the ones ive found are either, too expensive, it would make more sense for me to buy a whole new phone at that point, or they have no components, or they are also locked.
da
Aggiungi la tua risposta
Ed Montero sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 18,899
