Salta al contenuto principale
Part of the 15 series in Dell’s Inspiron notebook line, the 3520 model was released on October 18, 2012. The Dell Inspiron 3520 is a 15 inch laptop that is both affordable and capable of meeting a variety of needs.
20 Domande Visualizza tutte
Screen distortion,have replaced screen
I have a Dell 3520 that the screen was cracked ,I replaced it and it is distorted. Using an external monitor works fine. Do you think I need to try another screen or something else.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Try disconnecting the video flex cable from the motherboard video cable connector and gently (stress gently) clean the connecting end of the cable (both sides if double sided contact strips) using a Q-Tip lightly moistened with Isopropyl Alcohol 90%+. Ensure there is no cotton 'lint' from the Q-Tip left on anywhere when finished. (Shouldn't happen if the Q-Tip was moist)
Allow to dry thoroughly, (won't take long as it's alcohol), reconnect and see if it has resolved the problem.
If not you may also wish to do the screen end of the cable the same way.
If still no good it might be a problem with the screen. The only way to prove this is to try another one.
Do this with the battery removed of course.
Punteggio 1
1 Commento:
I will try this, thank you
da
Aggiungi la tua risposta
john sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 126
