Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Lightening port press hard to get the iPhone 6 to charge issue
Hi, I have a issue with my iphone 6 that I have to apply pressure to the lightening port to get the iphone 6 to charge. How can I fix or troubleshoot this issue?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
hi stephen sizensky
i tink some dust inside the charging port... just clean the dust it will work
Punteggio 5
2 Commenti:
Hi, it worked for a while then it suddenly stopped working. I cleaned again. What are some tricks of the trade for cleaning?
da
Anything small and pointy will work. Try using an alcohol wipe. Make sure you let it dry before plugging it in. Make sure the cable is flush with the phone. If it isnt there is still more dust to get out. It can take a few tries to get it all out
da
Ok, so gently clean with something small. Metal is ok. Be gentle. If that doesn't take, replace the lightning dock. Here's a guide
Sostituzione gruppo connettore Lightning iPhone 6
Here's parts
iPhone 6 Lightning Connector and Headphone Jack
If you don't trust yourself to do it. Don't. Any good repair shop should have this done in 20 mins, for $40
Immagine iPhone 6 Lightning Connector and Headphone Jack
Prodotto
$19.99
Punteggio 1
This is a simple fix.
Your charging port is dirty. Filled with fine dust particles or pocket lint. Basically, the white part of your charger should touch the phone itself. If there is a gap, it'll need to be cleaned. The harder you press, the more compact it becomes. Use a tooth pick to dig at the port. Be careful not to damage on the prongs. These are near the bottom. I don't recommend using a metal pick as it damages the port very easily. Tooth brush can sometimes work as well. Do this and you'll be up and running in no time.
Punteggio 0
2 Commenti:
vinod above basically said the exact same thing.
da
There was no answer as I was typing this answer. Posted it and noticed someone else posted something too.
da
Aggiungi la tua risposta
Stephen Sizensky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 672
