Salta al contenuto principale
La Canon EOS 5D Mark II è una fotocamera reflex digitale (DSLR) full-frame con sensore CMOS da 21,1 megapixel, dotata di funzionalità di registrazione video.
How to replace usb port
how to repalce usb port
Questa è una buona domanda?
Punteggio 3
1 Commento
Thank you very much, Pfaff, for your kind response. I agree that sending to Technical Service will be the best.
But I'm in a hurry in the middle of a project and no time left.
Will go ahead with your so clear instructions.
Many thanks.
Dick
da Condividi
Aggiungi un commento
2 Risposte
Risposta più utile
@dicktracy ,Dick, This is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a couple links to a tear down guide/vid to get you inside the camera to check the charge port and will also post a link to video showing what is involved in repairing a mini USB attached to the board( not your device, will show what is involved). If not wanting to do the repair yourself have a good camera/computer/cell phone repair shop have a look and estimate repair. I have a feeling the camera shop would tell you to replace the whole motherboard. Good luck.
https://www.youtube.com/watch?v=UOb55J09...
Sostituzione del pannello frontale della Canon EOS 5D Mark II
https://www.youtube.com/watch?v=XgGkCjNS...
Punteggio 4
1 Commento:
@dicktracy, Dick, Your welcome, good luck with your device and thanks for posting back.
da Condividi
I also had this problem, had it quickly repaired by these people:
https://www.fantastecne.com/repairs
Got it done very quickly and also had camera cleaned and serviced
Punteggio 0
2 Commenti:
How much did it cost then?
da Condividi
How much did they charge?
da Condividi
Aggiungi la tua risposta
Dick Tracy sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 22
Tutti i Tempi: 5,087
