Salta al contenuto principale
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Domande Visualizza tutte
Charging problem after battery replacement
Replaced the battery on my iPad 3 today due to the old battery not charging. The problem I am having is after I replaced the battery the iPad now continuously connects and disconnects while plugged in. I have triple checked all of the connections and everything is plugged in properly and all connections are clean. Any idea as to why this is happening?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
When you say you have triple checked the connections, have you checked to make sure the contacts on the battery are making a good connection to the motherboard? Did you test the charging and functionality before closing the iPad back up?
Punteggio 1
1 Commento:
I initially thought that might have been the issue so I put a small shim under the battery contacts. That did not solve the issue. I closed the iPad back up, but it's easy to tear down again if I need to because the adhesive needs replaced.
da
Sounds like it might not have been the battery that was the culprit in the first place. Do you have a new charging port to try? Worst case scenario it might be an IC issue, more specifically the U2 IC might be fried.
Punteggio 1
1 Commento:
I don't have a new charging port, but I can easily get one. I'll replace it and update.
da
Aggiungi la tua risposta
jeninholland02 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 119
