Makes beeps when the pc turns on and pc dispaly doesnt sho
When my pc turns on it constalty makes beeping sounds and doesnt stop the diaplay doesnt turn on,the monitor works fine
Questa è una buona domanda?
The 5 beeps is a memory or motherboard problem. I would remove all but one of the memory modules and test each one individually and find the one that may be bad.If the PC beeps 5 times with all of the single memory modules tested at a time, then the motherboard is shot. Hope this helps
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,251
3 Commenti
joseph 5052 are you saying it beeps continuously? As soon as you turn it on?
da oldturkey03
Hi,
Is there a pattern to the beeps?
Count them and see if there is a pause and then it repeats the sequence over and over.
It can be up to 9 beeps in a row or even a code such as 1 beep 1 beep 4 beeps 1 beep 1 beep 4 beeps or something like that.
Listen for the pause between the beep pattern. It is slightly longer than the time between the actual beeps
da jayeff
it happens when i turn it on it makes 5 beeps and a pause and keeps going and does'nt stop.
da joseph 5052
