Salta al contenuto principale
Repair guides for Android cell phones manufactured by ZTE.
1282 Domande Visualizza tutte
Setting up Voicemail on my ZTE cell phone
How do I set up my voicemail?
Questa è una buona domanda?
Punteggio 13
9 Commenti
My phone number is not listed on the phone.. But I know it.. But when I did your voicemail setup it says number not set and it won't let me type it in. It's a safelink phone
da
What is the phone number for voice mail??
da
Hi @haydr,
Go to your service provider's website. The information should be on there.
Search for Voicemail setup.
da
!&&* I can't find the word, voicemail anywhere in settings
da
Hello I've been trying to set up voicemail lm having so much trouble...I've trouble shoot all
da
Mostra altri 4 commenti
Aggiungi un commento
4 Risposte
Soluzione Prescelta
@rustynail ,Susan, ZTE cell phone Setting up Voicemail. From home screen, tap the phone icon, tap the menu icon at bottom right of screen, tap settings, tap voicemail, tap setup, tap voicemail number, enter the desired voicemail number. You can also check the links below. Good luck.
http://www.wikihow.com/Set-Up-the-Voicem...
https://support.t-mobile.com/docs/DOC-15...
Punteggio 5
1 Commento:
I did exactly what was stated to set up voicemail. Put number in but still not set up. Nothing in phone to add a greeting. Please help, can't always answer phone & miss calls & person cannot leave message.
da
Punteggio 1
1 Commento:
Hi,
Did you try the answer above?
You need to give more information if you want help as you haven't provided any at all!
What is the make and model number of phone?
Have you checked your mobile phone service provider's website for instructions on how to set up voicemail?
What have you tried?
da
Hello there, I don't remember my Voicemail password. How would I change my password?
Punteggio 0
1 Commento:
Hi @darknight ,
You'll need to contact your mobile phone service provider and get them to reset it back to the default value for you.
da
Hi @jburchfield97,
You don’t state the model number of your ZTE phone, did you try as suggested by the Chosen Solution above?
Open the Phone app and then tap the 3 vertical dots icon lower right of screen (or the right hand soft key below the screen) and tap Settings > Voice call > Voicemail > Setup > Voicemail number.
Once there you have to insert the Voicemail number (or information) provided by your mobile phone service provider. Go to your mobile phone service provider’s website and search for Voicemail setup to find the information.
Punteggio 0
2 Commenti:
Hi there, I have the ZTE Blade A3 L, having similar issues to others above. Followed the instructions, got to the voicemail setup, advance settings, setup, but then it brings me to a section to input my voicemails number <not set> and I can’t click on anything.
Any suggestions?
da
@Mike McNeil
Have you switched providers?
By that I mean did you have voicemail before on the phone but with a different provider?
have you checked if voicemail is still active on your number with your current
provider?
da
Aggiungi la tua risposta
Susan Gott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 132
Tutti i Tempi: 37,210
