Green color on screen
Greenish on people and background
Questa è una buona domanda?
@nanasgirls4 the hue and color temperature settings in your menu regulate the amount of tint that will be displayed. The hue controls the amount of green. Try to adjust both settings to see if that decreses the green tint. In general since we do not not your TV's model number, you do want to make sure that all your settings are reset. Use your main set-up menu for that. Menu>Picture>Picture Reset If it has a system reset menu then you do want to use that. You also want to check if the green tint is on all inputs i.e. HDMI component coax DVD etc. Worst case scenarion you may have to remove teh back off your TV and take a look at the the wires on the T-Con board and see if the cable to the LCD is properly seated and shows no corrosion etc. Post some images of your discolored screen so we can see what you see. Use this guide for that
@guypersonthing sorry to hear that. Which part did not work? Adjusting the color? Or the part where you removed the back of your TV and checked the wiring and the T-con board? Or the part where you posted the pictures of your boards etc. You see, dont tell people to „ go &&^& yourself“. If you want some help with your TV’s issue, You need to ask a proper question and follow the advice given. Have a great day!
My Samsung TV has green and purple coloring, I've tried soft reset, I've checked the wiring and the color, contrast function is not responding, and this is all of a sudden, what can I do
I had this issue also, and one of the cable box hoookups was in the wrong receiver. Make sure they all line up to the correct receivers. Fixed this issue immediately.
mine is doing the same is there something I can try it's Mitsubishi DLP 80 INCH green on edge of faces
My tv was fine, but all pictures connected with my Toshiba recorder had an ugly cyan tint. The recorder is connected to the back of the tv with a scart connection. I gave this scart connection a wriggle and pushed it firmly home. CURED.
worked for me (pushing it in more, also down) on my LN-T4069F using HDMI
I had the same problem with my Samsung led tv. Open the back panel, there is a serial cable that goes to the top of the tv. In manufacturing they twist that cable and kink it. Remove the tape and straighten the cable. Route the cable as straight as possible and tape it back down. This is what fixed my green screen issue.
I have a Samsung Smart TV and it just did this, but only for Cable. After a quick search, I decided to try to unplug it for about 60 seconds, then replug it in. This resolved the issue for me.
I have samsung 24 inch smart tv and the screen is a light green colour can you tell me how to fix it please tell me !
I'm sure you can tell me how to fix it!
the replies to that problem have mentioned making sure all connections are solid and secure, and correct, ie: hdmi, cable, etc. if that doesn't work, try a reset Menu>Picture>Picture Reset. If it's still not helping try unplugging it for at least 60 sec. Hope this helps.
Ultime 24 Ore: 19
Ultimi 7 Giorni: 117
Ultimi 30 Giorni: 568
Tutti i Tempi: 68,775
3 Commenti
@nanasgirls4 what model is your TV?
da oldturkey03
32 in samsung full HD 1080p
da James Lawrence
I have a Samsung, ps43e450a1wxxu, s.n…b46h34pc704664k, green ting on all faces and background, wot do I do to fix this please, wot do I need to get
Thanx for your help guys
Keep up the good work
da Graham Godwin
