Salta al contenuto principale
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Can I upgrade from a 2.16Ghz to a 2.4Ghz Logic board?
I have a 13" Macbook white 2.16Ghz Energy Star (mid '07) A1181 logic board core 2 duo (I know this cuz it uses the JST 3 wall heat sink). The GMA950 video card became corrupted and now I have to replace the entire logic board (those bastards!!!). I see on Ebay some A1181 logic boards that are selling between $250-$350, and I'd much rather repair the problem than have to buy a new computer for double or triple that. I can definitely replace the logic board myself, but if I can increase the processor speed while I'm at it, I don't see why not--especially when the price difference between the two logic boards is only $50. I see that the connectors are pretty similar. Do you think this is possible? If so, would it be a clean swap or would I need to replace other parts as well? Thanks in advance!!!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
The 2.16 is the highest you can go in your series. Here's a list of the boards that will work in your machine: http://www.ifixit.com/Mac-Parts/MacBook-...
Punteggio 2
3 Commenti:
Nice research +
da
+ good answer
da
You can also get the logic board repaired for $250 here: http://www.dttservice.com/macbook.html
da
Why don't you attempt to fix the broken logic board first before buying another one. Google how to reflow a gpu. I have done this before and if you already have the logic board out then you might as well try it. All you need is a hot air gun and aluminum wrap foil. I had an imac with the a faulty gpu and some guy on here gave me detailed instructions on how to reflow the graphics chip check out this post:
video graphics and boot issues
I hope this helps, good luck!!
Punteggio 1
2 Commenti:
Thanks a lot guys!!! I tried reflowing the gpu and it did not work....sigh! If the computer display works perfectly in safe mode but not in regular mode, can I disable the video card somehow?
da
Then again, I heated up the big chip in the middle (945GM). I did not heat up the other Intel chip above it cuz I believe that's the 2.16Ghz processor, right? Perhaps the gpu just didn't get hot enough?
da
Put a blob of (lead-free) solder on top of the chip while attempting the reflow. When that melts and you keep the heat up for another 30-60 seconds you can be assured the "spider-legs have also resoldert. The reason for the lead free solder is that it melts at a higher themperature than ordinary solder.
If that doesn't work - well, get yourself a logicboard.
Punteggio 0
2 Commenti:
Hey guys,
I appreciate all of your input. I ended up buying an infrared thermometer and I reflowed the GPU at 450 degrees F and followed the directions from forums. I'm sure the video card works now, but now my computer won't start. I must have fried it. Bummer....I guess now I'll look into buying another computer or replacing the logic board. Unless u have troubleshooting tips on how to start the computer up. Lol
Cheers
da
Does it make any noise when you press the power button? like do you hear the chime or the HDD spinning? It could be just a loose cable or something like that. But there is a good chance you fried other components while doing the reflow if you didn't use enough aluminum foil.
da
Aggiungi la tua risposta
Rmeister007 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,698
