Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Small Metal Part Fell Out?
I was replacing my brother's iPhone 5 battery and after opening the screen panel a small metal part with two holes fell out and I have no idea where it goes. Also, this black strip towards the home button appears loose and I'm not sure where that goes, either.
Photos below:
https://goo.gl/photos/cRzqfSffKxCntwVE9
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
the small metal part on the left hold the home button flex in place once you connect it. is there a screw on the home button flex to the right when you're looking at the back of the lcd? if you lost if you could just use a bit of double sided tape I guess where the screw ought to be.
Update (01/26/2017)
you're welcome, you could even forget about the metal part, it won't matter anything if you do, it's a headache to put back. I do it for customers of course but if it was mine....depends on my mood if i were to put it back. it needs to first get set into the top area, there are two notches in it then forced down towards the bottom. you're welcome!
Punteggio 1
1 Commento:
Ah, I see! Thanks for the insight. It appears I lost the screws but I will definitely try tape. Thanks again!
da
Aggiungi la tua risposta
Hannah D sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 147
