Salta al contenuto principale
Looking for a samsung Galaxy Tab E 8.0 digitizer.
I have a Samsung Galaxy Tab E 8.0 SM-T377V in the color black that has some light scratches on the front of the touch screen glass. I am looking for a replacement digitizer but am not able to locate the part. I have tried amazon, ebay, and Google and have only come up with the LCD which as far as I can see is functioning perfectly. Any one know of a parts vendor that I can contact for a replacement?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
The digitizers just went up on ebay. They are about 40.00. Just do a search for galaxy tab e 8.0 screen replacement. They are all from China so it takes a bit to recieve, but at least they are available. I just ordered one.
Punteggio 0
1 Commento:
Yeah those are the ones. Going to order 1 myself. Not sure why there was not any now there is a few sellers.
da
Risposta Più Utile
The part is here:
http://www.ebay.com/itm/like/36140820898...
Punteggio 1
11 Commenti:
The link you have listed is for the 310 series and that is a Tab 3. I'm looking for a digitizer for a Tab E 377v series. There are generally differences with the pin out on the ribbon cable connector. Buying that and installing it could damage the connector on the logic board and /or lead to a purchase that can not be used at all.
da
I'm looking for the same part can someone give me any suggestion
da
Incorrect, as I said above twice I need the digitizer not the LCD. The LCD is the liquid crystal display. That component produces the image that we see. The digitizer is a separate part being the top glass that transmits touch signals through the ribbon cable to the logic board.
Again I only need the top glass or aka digitizer.
da
Have you actually asked the seller if the digitizer and display are 2 pieces or one?
da
Mostra altri 6 commenti
Hi,
Have you thought of this option?
It only says that the LCD is broken - not working, nothing regarding the digitizer, which looks undamaged. That doesn't mean it works of course. Perhaps contacting them might be useful.
http://www.ebay.com/itm/Samsung-Galaxy-T...
Punteggio 1
9 Commenti:
I thought about that but then you run into the adhesive problem. New digitizers have (generally) a precut adhesive on the inside. I don't think there is a way to remove the LCD from the backside as the LCD drops into the midframe lining up in the preset channel. If I took the digitizer off naturally you run a risk of damage and the adhesive is ruined. The digitizer on my tablet is not bad it works flawlessly but has a few light scuffs. As a perfectionist it bothers me, so I am now questing for a new digitizer to restore it to a factory like new condition.
da
did you find this part?
da
No I have not. I can't seem to find a vendor that has a new digitizer. I contacted a store on ebay and they added me to a list. I guess that will be a when and if they get them type thing.
da
Are you replacing the digitizer simply for cosmetic reasons? If so, most light scratches visually disappear when you apply a screen protector.
da
The scratches are deep enough for a finger nail to catch on if dragged over. Yes it is cosmetic because it is still 100% functional but again I know that they are there and it bugs me.
da
Mostra altri 4 commenti
Aggiungi la tua risposta
Kari sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,612
