Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
Would it technically be possible to add headphone jack to iPhone 7?
1. I know there is some Lightning to headphone adapters that split the connector into a Lightning port and a headphone jack. Is there enough empty space in the phone (or enough empty space from removing something not necessary) to add a headphone jack and the chip from one of those adapters?
2. Would it be possible to then de-solder the Lightning port and solder the adapter to it, then re-add the port connected to the adapter?
3. If possible, how hard would it be?
If it isn't possible with the normal iPhone 7, what about the 7 Plus?
Questa è una buona domanda?
Punteggio 0
1 Commento
There is zero "extra space" in the iPhone 7.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Ehhh I mean technically way on the outside, it's possible. But you couldn't really desolder the headphone jack, exactly, technically it's a press solder onto a ribbon cable. So you'd have to somehow build a custom ribbon cable to fit an extra jack. So it's not really possible, and no there really isn't any extra room, and no it wouldn't be possible with a 7+. I appreciate the thinking outside the box, however it would just be really difficult
Punteggio 3
Everything is possible, but You have to project your own iOS, lightning flex, and PROBABLY new paths on maiboard :)
You can do it, it only depends of that, how rich you are, and how smart people you will ask for this.
Punteggio 1
Aggiungi la tua risposta
Arie Copley-Radder sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 173
