Mass air flow sensor problems
My mass air flow sensor keeps getting wet and I can not figure out why. I thought it was because it was located on the bottom of the car but I dont think that is the case. Im wondering if it may have to do with the red and yellow round piece near it any help would be appreicated.
Update (01/22/2017)
Questa è una buona domanda?
4 Commenti
When you say it keeps getting wet, what do you mean? Are the internal workings of the MAF sensor getting wet and giving bad info to the computer, or is the portion outside of the air intake system getting wet and causing issues in the wiring? A picture of the "red and yellow round piece" and the surrounding area might also help.
da Geoff Ice
[image|1009188][image|1009189]
This box is part of the air intake I believe and I was told it was full of water. It seeems like the red and yellow piece measures how much water is in there. All of this leads down into to spot where the MAF is housed. Every time I take my MAF sensor out it is wet and the one I just replaced was rusted because it was wet for so long.
da redarkulus_7
that little red and yellow piece is actually the air filter meter it tells you if there's an airflow restriction it has nothing to do with water
da Ryan Burns
I’m sorry to jump on this thread so long after it closed but I have a 2007 Focus cc and I can’t find the maf sensor anywhere … it’s definitely not at the top between the air filter and the manifold .. I notice you said your was at the bottom I don’t suppose you could help me locate it ?! Also I’m being told that perhaps my car doesn’t even have a maf sensor .. but the part I brought was based on my reg number .. is your car diesel or petrol ?
da Sonia Graham
