Salta al contenuto principale
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Domande Visualizza tutte
Does anyone put a SSD in this great iMac ?
I'd like to do that and also to put a ide HD instead of the DVD Combo.
Or did you find a tutorial on the net ?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Soluzione Prescelta
I did it.
I bought an box adapter (2.53 -> 3.5") but it's only to fix it mechanically in the iMac, no need for a plug adapter. Some even does it with tape....
Anyway it's great to have a SSD !
only bug, I taped back (wrongly ?) the thermal sensor on it, and the SSD temperature is now saying always 128° (iStat Menu). But the fan turns at 1300rpm.
Nothing to worry about.
Punteggio 1
1 Commento:
That's great--please accept your answer now to clear the question.
da
Risposta Più Utile
You can add an ssd just fine,
There is no such thing to my knowledge as a 3.5" ssd - you will need an adapter bracket.
Jumping pins is for fooling the thermal sensor on the new 27" iMac. not relevant for your imac.
MCE TECh makes an optibay that will allow you to use a 2.5" ata drive harddrive in place of the ata optical drive. Powerbook G4 optical drive's are the same size and shape as the one in your imac.
Optibay
Punteggio 3
1 Commento:
You Can put a 3.5" SATA SSD in the mac, but you cannot put an IDE hard drive in place of the DVD drive, However, you can put a 2.5" Laptop SATA drive in place of it. The iMac Lacks an IDE Bus, but has two SATA buses, whic can be replaced with one 2.5" SATA drive, and one 3.5" SATA drive
Punteggio 0
1 Commento:
Optical drive is ATA
da
From what I've heard about putting SSD's inside, you have to short two of the pins, and sometimes get unreliable performance.
Punteggio 0
1 Commento:
Good info, wrong computer.
da
may I replace the 3.5" standard HD with a 2.5" SSD (I wouldn't like to replace DVD... I use it!)?
Would I need an adapter? Thanks!
Update
One more thing: can i put two 2.5 HD in the 3,5 vane? If I could I would have a small SSD+large HDD... I think I would need an adapter... Does it exist?
Ps: for the moment I bought an ibrid SEagate Momentus (500Gb 140euro) because it was the best for my needs and pockets.
Punteggio 0
Hi Guys.
I'm gonna try and replace the hard drive on my 24 inch iMac (Processor 2.16 GHz Intel Core 2 Duo). I hope this isn't too tricker for a first timer?
I'd like to install a SSD? It currently has an Intel 250 gb drive what would you suggest is the ideal replacement SSD; size and type?
Ideally can you suggest a make for me please? Another intel? I know it will have to be a 2.5" with an adapter bracket to fit the 3.5" space of the original drive.
Advice please?
Punteggio 0
Aggiungi la tua risposta
Pilot sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 7,813
