Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
Touch ID not working with screen replacement but original home button
Hi all.
I can't seem to find any answers to this and it has me stumped.
I have replaced a display on a iPhone 6s but have carefully transferred the original home button to the new assembly but the touch ID will not work.
I have also removed the original lcd backplate from the broken screen and connected the home button to that and then that to the board with the same result.
Can anyone help me?
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
i think you have damaged the FTP ribbon. i have seen this so many times. the ribbon has perforations at the top of the flex on the lcd part. check the perforations for breaks where it leaves the back of the lcd metal shield. good part is you can fit a replacement ribbon just not the actual button
Punteggio 0
1 Commento:
Thanks for your reply. I don't think that is the case though. I was so careful when performing the replacement, and like I said in my original post, I even swapped it for the original with the same result
da
Aggiungi la tua risposta
domhaywood sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 125
