Salta al contenuto principale
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Rear camera not working , flash disabled
I have a customers iPod touch 5th. The rear camera is black. Shutter is probably not opening. It's also says the the flash is disabled until the device cools down but the device is not hot. I tried the basics of a hard reset and resetting the settings nether worked. Any ideas? Should I try to replace the camera or is that a waste of time?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
replace the rear camera, should resolve the issue for you, as the shutter may be failing, and replacing it should fix it. :-)
Punteggio 1
Aggiungi la tua risposta
AppleCrack sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 857
