Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
iPhone not powering on but gets hot (not logicboard)
I have an iPhone 5c that I have refiently refurbished however when I come to turn the phone on there is no response. I have left the phone on charge and it seems to get warm. It is not the logic board as I have taken the logic board out and tried it in another phone and it works fine. I have plugged the unresponsive phone into my laptop and iTunes is picking it up. Any ideas?
Questa è una buona domanda?
Punteggio 0
2 Commenti
I forgot to mention I have also tried different screens so it could not be the screen
da
Have you tried a different battery?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I think you need to retrace your steps. Look at all the variables and try to eliminate them one by one.
You confirm the logic board works and that the screen works but that the two don't work when they are together in the same housing. If that is true, then it sounds like the problem is related to the housing. There must be a problem with the grounding or a flex is pinched.
Punteggio 1
Aggiungi la tua risposta
CustomPhoneUk sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
