Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Horizontal White Lines appears after a while
This problem is a little trick. When this iPhone 5 unlock it is normal until 2s, after that some lines shows up and keep there. I have already replaced the battery, flex cable and the last one was the display from china. I really don´t know why the owner was so cute with this little iPhone. kkk
Could anyone help me?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Thats 100% bad display, seen it countless times
Punteggio 1
1 Commento:
I am not sure what is the reason, but I am almost sure that is the display.
da
Risposta Più Utile
If it's not the display, which it sounds like you're using cheap parts, then take a look at the digitizer socket, see if it looks clean and in good condition
Punteggio 2
2 Commenti:
Hello iMedic,
Yes, I am using cheap parts to replace it.
I took the display out to look better.
*I upload a picture and a new video above.
The digitizer socket looks ok, just on the plastic around I can see
some scratches. I have tested another display before that with no problem.
Anyway, Could be these scratches the reason of the problem?
The trick I cannot understand is why the iPhone starts ok then some seconds later get it worst.
da
I know people get particular about the parts that they use. It's fine if you want to use whichever brand works for you. But have you tried using a quality display, to rule out the display being an issue?
da
Aggiungi la tua risposta
gpxdigital sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 944
