Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Error -36 with SSD hard drive
Hello everyone,
I just changed my hard drive with a new one which is a SSD "samsung EVO 850 EVO". It works well and I can write this message with my mac without problem.
The only one is when I'm copying more than one file on my computer from an external disk. The error -36 is displayed and I need to copy each file one by one (and sometimes it doesn't work). The hard drive is formated with a GUID partition and a MAC OS extended (journalised, encrypt). One of you has ever encounterd this issue and know how to fix it ?
Thanks a lot,
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
You'er hitting a known issue with the drive cable.
You'll need to replace it, follow this IFIXIT guide: MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement. You'll want this version of the cable (the better design): MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable - Apple P/N 923-0104
Immagine MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Prodotto
$34.99
Punteggio 2
Before completing any work, please do a complete backup if this Mac. The last thing you want is some data stored on the drive to get lost in the process. Thanks!
Punteggio 0
Hello Justin and Dan,
Thank you for your quick answer !
I'm going to replace it, I hope it will work.
Punteggio 0
Aggiungi la tua risposta
Arnaud G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 118
