How to fix dents/scuffs in plastic
Hello,
I am going to get a slightly water damaged 5c to fix, but its in pretty bad condition. the screen is cracked, but LCD fine. It has a few dents on the housing on it, but still works. how can i fix these dents? Would sanding the corners and then polishing it work?
Questa è una buona domanda?
3 Commenti
@gigabit87898 , are you pushing the dents out of metal or plastic and the same as sanding is it metal or plastic, I will try to help answer your question.
da L Pfaff
@lpfaff1 It is the plastic
da Gigabit87898
@gigabit87898 , Now that I see what you are dealing with, maybe just sand and polish and live with the small dent like imperfections, gouges like that normally get filled with a little plastic fill and sanded smooth, primed and repainted, probably more work than you want to do. Good luck with your device.
da L Pfaff
