Salta al contenuto principale
Released January 2015. Android smartphone.
Phone doesn't charge anymore
My phone is the redmi 2s prime edition and recently when i plugged it into the charger to charge overnight, i found out that in the morning that it doesn't charge anymore and the phone has switched off as well.
So when i plugged another cable to the charger and tried to charge it, it still doesn't work, and then tried another charger from my older phone but it still doesn't work.
So i tried plugging in the original cable which i used it to charge the phone overnight to my laptop and i found that it has some power error because once i plugged it in, windows gave me an error about a power surge which had never happent before.
Then i tried another traditional (Classic) way of charging the phone battery by using an old USB cable and then using the ends of the positive and negative cables i plugged them into the battery and that gave it around 5% of charge by which i managed to start up the phone.
So does this mean that the USB Charging port of the phone is burnt ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Possibility of the USB charging port on your phone to simply get spoiled, it's a common issue, just change the port and you should be good to go.
Punteggio 0
1 Commento:
So i checked online and found that there is a separate module for the charging port, i think ill buy that and replace it with that
da
Aggiungi la tua risposta
Kanishka P sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 39
Tutti i Tempi: 480
