Salta al contenuto principale
Il telaio W123 copre le 240D, 300D, 300TD, 280E e molti altri modelli di coupé, berline e station wagon Mercedes prodotti dal 1977 al 1985.
How do I replace the engine shut off switch?
i have been looking all over the internet and can't find any videos or even an explanation on how to replace the engine shut off valve. i have a 1984 Mercedes 300D turbo diesel. i see where the valve is however there is only about 2 inches between the injection pump and the oil filter housing and the valve is right in between. - do i need to remove either to get the valve out? - do i need to drain the oil to change the valve? - is there a specific way the valve is set into the injection pump?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
No, you don’t need to remove the injection pump (IP) or oil filter housing. Indeed, doing so would be a major task. You can unbolt the plastic VCV on top of the injection pump and swing it out of the way for a better view, but not required. There are 4 bolts which take a 10 mm wrench. A ratcheting box wrench will make the job much faster. There isn’t enough room for a socket wrench, as I recall.
A trick in removing and installing the shutdown valve is to angle its body towards the engine block since there is a smidgen more room on that side to clear the filter housing. It also helps to suck in the stem w/ a hand vacuum pump, but that might not be possible when the diaphragm is torn. Otherwise, push in the stem with your finger.
Yes, it is important how you insert the new shutdown valve into the IP. The vacuum port should be up. The L tip must go past a flat lever, so that it can pull backwards on the lever (can’t see it, but imagine). That lever is closer to the engine block. If angling the shutdown valve in from the block side, that should happen naturally since the tip should then slide past the lever. If correct, you will feel no resistance when pushing the shutdown valve to seat on the IP and should feel it pull on the lever as you move it back. If you must force the shutdown valve forward (compressing its stem), it is then pushing on the lever (incorrect), which would cause high fuel flow and a high-rev’ing engine on startup which could cause damage. Not much to fear since it is fairly straightforward and common sense. You will need 2 new gaskets with the shutdown valve, one on each side of the factory metal spacer.
Punteggio 1
Risposta più utile
@savageray ,renalesraymond, Read through the links below, 1st link is the procedure to change SOV . 2nd and 3rd link is good info. Good luck.
http://www.dieselgiant.com/repairyourshu...
https://www.youtube.com/watch?v=ohDmGj8W...
https://community.cartalk.com/t/1984-mer...
Punteggio 2
2 Commenti:
wow thank you so much L Pfaff. you are amazing. for the past month i have been searching all over for an explanation on how to replace it. i know the part is bad due to the oil being sucked into the vacuum line. i ordered the right part about 2 weeks ago, but thought it was something else causing the oil to get into the vacuum line. well now i know better. man thees cars are hard to get info on some times. most of the repairs i have done so far are not in the repair manual. but thank you. now i have to wait for the part to come in.
da
@savageray , Raymond, have to agree with you, info is hard to come by a lot of the time. Thank you for posting back, have a good day.
da
Aggiungi la tua risposta
renalesraymond sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 36
Tutti i Tempi: 3,081
