Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1234 Domande Visualizza tutte
iPhone 5c won't charge past 3%
My iPhone 5c won't charge and the charger is brand new but after I plugged it into my moms Dodge Journey USB port my phone stoped charging , now it dies and turns back on but doesn't charge past 3% and the lighting bolt doesn't pop up , does it need a new battery ? Help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The iPhone charging subsystem can be damaged by non-MFi (Made for iDevice) certified chargers. Based on the sequence of events you describe, this is what happened to your phone. Cheap dollar-store charging bricks also can cause this.
While it is possible that your battery is defective, I believe that the Tristar(U2) IC on your device was damaged by the USB port. This is not a DIY repair unless you have experience in micro-soldering.
If you have access to a known-good battery, you can always replace it. If a known-good battery does not charge, then it is a U2 problem.
Sostituzione batteria iPhone 5c
The 5C also suffers from micro-fractures on the logic board so this could also be the root problem on your device. A qualified repair shop that does micro-soldering should be able to troubleshoot your device properly if you don't want to do it yourself.
Punteggio 1
Aggiungi la tua risposta
Shadiamond sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,883
