Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
5c in swimming pool and doesn't power on
My iPhone 5c went in swimming pool and now it will not power on. I had it in rice for a couple months, then put it on the charger overnight and tried to power it up. The apple came on the screen but it wouldn't do anything else. I haven't verified that water actually got inside because I never opened it up and there is no visible water damage. Based on this info what would be the likely problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@lucky2 biggest problem here is this " rice for a couple months" Rice does not work. It is the equivalent of not doing anything. Your phone will most likely have died of corrosion damage.
The proper step would have been to not try to turn it on, to charge or to sync is. This could potentially make a bad situation worse since it could shorten more components on the logic board out. Disassemble your phone by using this guide. Clean your phone with 90%+ (or better) isopropyl alcohol. Use this guide to clean your phone. It was written for a 3G but all the steps are pertinent to your phone as well. Inspect your board for any missing or damaged components. You must remove all the EMI shields to clean the board. Once properly cleaned, replace the battery , then reassemble and re-evaluate. Water damage is the hardest to diagnose and to repair since almost any part can have failed.
Immagine iPhone
Guida
Riparazione danno da liquidi iPhone
Difficoltà:
Difficile
1 - 2 hours
Immagine iPhone 5c Scheda madre
Guida
Sostituzione scheda madre iPhone 5c
Difficoltà:
Moderato
1 - 2 hours
Punteggio 1
Aggiungi la tua risposta
Pete sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 52
