Salta al contenuto principale
I piumini ti avvolgono in un morbido calore, isolandoti dal gelo e dal vento. Sono altamente comprimibili, estremamente leggeri per il calore che offrono e ultra confortevoli per l'uso quotidiano.
Zipper gets stuck all the time
Patagonia TorrentShell jacket
Zipper of my Patagonia TorrentShell gets stuck all the time. It stops in neck area when trying to get it closed. Fabric of inner stormflap gets stuck between zipper.
Has anyone tried to sew a some kind of reinforcement to stormflap? Maybe repair tape in flap will prevent it getting between zipper?
Questa è una buona domanda?
Punteggio 0
2 Commenti
villemitikka - I had this issue too and took my jacket to Patagonia - they ran 5 lines of stitching down the inside flap to stop it from snagging and it's worked perfectlyl. They have a free of charge repair or replace area in their stores.
Hope this helps!
da
John - Thanks for your answer. Sounds good and easy. Got to try stitching by myself.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Here's the guide on zipper repair for the Patagonia:
Sostituire una zip frontale su una giacca in piuma Patagonia
Punteggio 1
Risposta Più Utile
villemitikka , I do not own this type of jacket, on a jacket that I had, did have this problem, so what I did when zipping up I would use my index finger to keep (guide) inner flap material away in the collar/problem area while zipping up. Worked for me. Good luck.
Punteggio 2
try using a old candle and run it up and down the zipper a few time to both sides of the zipper it will make it slide with ease
Punteggio 1
Aggiungi la tua risposta
villemitikka sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 98
Tutti i Tempi: 6,727
