Salta al contenuto principale
Altec Lansing, Inc. is an American audio electronics company that primarily produces loudspeakers and associated audio electronics for professional, home, automotive, and multimedia applications.
9 Domande Visualizza tutte
Does anyone have the schematic for Altec Lansing acs33?
The sub stopped working. All else works normally. The woofer checks ok. Would like to troubleshoot amp.
Questa è una buona domanda?
Punteggio 0
1 Commento
did you get any ACS33 schematics?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sometimes it could be due to bad IC chips, transistors, or failed capacitors, etc.
If you have a multimeter, it would be a good start.
Punteggio 1
2 Commenti:
I was wondering if I can wire my Acs 33 sub to work with None Ace 33 speakers or without out. What is the audio in pins on the 6 pin din?
da
Josh my altec lansing vs5121 was 120v however the audio board used 18vdc! So now it's running off a ryobi battery! I added a mp3 blutooth card reader! It's awesome. I can get a acs33 for 6$ used. Would you happen to know the operating voltage of the board in that unit?
da
Aggiungi la tua risposta
teeb48 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 936
