Ambient light sensor not working
Hello -
Phone screen was cracked, replaced the glass via ebay service. Prior to replacing the glass i had no issue with the ambient auto light sensor dimming the screen based upon how dark or bright the room is.
Now the ambient light sensor does not work at all and is frustrating. I replaced the camera/light/prox flex with two known good and still no go. If you turn off and then back on the ambient light sensor it auto adjusts to just under medium brightness.
any ideas?
Questa è una buona domanda?
3 Commenti
So you paid someone on ebay to fix your screen?
My guess would be they did a glass only repair and either got glue in the prox sensor hole or didn't line up the bracket right.
Worst case scenario is they damaged the logic board. If it were me, I would contact the company that did the repair and pitch a fit.
da Josh W
Yea, ebay you can have glass only replacement on say an oem iphone 6s for $45. instead of paying $120 for a new working oem screen... I replaced the screen myself.
da Paul
i have the same issue and i also can't fix it. I orderd 10 cables from 10 different shops. When i connect the old cable with the broken microphone, the autobrightness adjust works fine, with the 10 cables it goes to under medium brightness.
da Hogen
