Salta al contenuto principale
Should I use my computer with no bottom shield?
Hi,
After few trials, it seems that my computer works without the bottom shield.
With shield I have a Kernel Panic just after turning on.
What are the main issues of runing without shields please?
Do you know how I could fix that to use the shield?
Thank you
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like your sheild is shorting something out. Hold it horizontally and eyeball it across the top to see if something is sticking up when the shield is off and getting pressed down. I don't know of any issues with running without on but possible overheating.
Punteggio 1
1 Commento:
good answer +
da
Aggiungi la tua risposta
Jonathan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 528
