Screen not working and power button also not working
How can i fix it? My Phone fell down the power button Is not funcioning same time i put inside sink of Water, help please
Questa è una buona domanda?
Start by telling use if the screen is broken ,cracked or just not turning on . Then if the phone got wet you need to take it apart and clean it. This tear down video should help .Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. If you have access to an ultrasonic bath then clean it with that . distilled water and a cleaning solution but if not then the IP alcohol and a tooth brush Now is the time to start drying out the phone. If the screen is not cracked set it ,just the screen nothing else , in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
This guild on water damage may also be of help
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 122
