Salta al contenuto principale
The Chromo Noria is a 7 inch Android tablet that ships with Android 4.4 KitKat. It comes in black, blue, pink, and white.
Why is my front-facing camera distorted?
My front-facing camera has been blurry for a while now. What could be causing this and is there a cheap fix for it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hey, thanks for your post! It's likely that your device's camera is being covered or distorted by something in front of it! Try removing the case and cleaning your device's screen with a screen cleaning cloth. Also, wipe down your device's case if it encapsulates the front-facing camera to make sure it's not a problem with the case. If the problem persists, I'd read the paragraph on the troubleshooting page about the front facing camera. You can check out the relevant section of the guide here.
Punteggio 0
Aggiungi la tua risposta
Kevin Nguyen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 210
